Lenovo ThinkPad X390 Yoga Display Replacement
  1. Lenovo ThinkPad X390 Yoga Display Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Safety Procedures:
    • Shutdown and Disable Power Supply: 1. Disconnect adapter. 2. Press F1 key to enter BIOS setup powering up Laptop. 3. Go to Configuration menu. 4. Select Power and press Enter. 5. Highlight Disable Built-in Battery and press Enter. 6. Confirm by selecting "Yes" and pressing Enter. 7. System will power down, and disabled battery.
    • Electrostatic Discharge (ESD) Safety: 1. Ground yourself to prevent static damage by wearing an ESD wrist strap or touching a grounded metal surface.
    • Remove the SIM Card Tray 1. Insert a straightened paperclip into the hole on the SIM card tray. 2. Gently push to eject and remove the tray.
    • Use a Phillips #1 screwdriver to unscrew the captive screws from the back of the device. The screws should not be removed from the back panel, so don't try to force them out.
    • Disassemble the Laptop: Remove the Bottom Cover and Battery: 1. Loosen five captive screws on bottom of laptop. 2. Use a non-metallic pry tool to carefully loosen clips along the rear cover. 3. Lift and remove bottom cover. 4. Disconnect internal battery cable from system board. 5. Remove five screws securing the battery and lift it out of system.
  2. Lenovo ThinkPad X390 Yoga Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
    • Disconnect Screen Cables: 1. Disconnect the LED camera cable and remove it from its guide. 2. Remove the antenna cables from their guides. 3. Disconnect the LCD cable and remove it from its guide. 4. Remove the Antenna Cables from the guide which is next to LCD cable. 5. Remove three screws from each hinge.
  3. Lenovo ThinkPad X390 Yoga Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Display Replacement, Display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X390 Yoga Display Replacement, Display: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the display connectors with a spudger or opening tool.
    • Remove the LCD Panel: 1. Lift the LCD panel and flip it over. 2. Remove the tape securing the LCD cable. 3. Disconnect the LCD cable and remove the panel.
    • Install the New LCD Panel Reinstall the LCD Panel: 1. Place the new LCD panel face down and reconnect the LCD cable. 2. Secure the connection with tape. 3. Flip the panel over and position it in place on the LCD unit.
    • Reattach the Bezel: 1. Place the LCD bezel back onto the LCD unit. 2. Secure the clips along the bottom edge first, then press down along the edges until all clips lock into place. 3. Align the new bezel sheet over the LCD unit and press down along the edges to secure the adhesive.
  5. Lenovo ThinkPad X390 Yoga Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble the Laptop: 1. Place base cover assembly onto hinges, close it over LCD unit. 2. Reinstall three screws into each hinge. 3. Reconnect and guide antenna cables, LCD cable, and LED camera cable into place.
    • 4. Place battery back into the system, secure with five screws, and reconnect battery cable. 5. Reattach bottom cover, aligning front edge first, and tighten five captive screws. 6. Insert SIM card tray and push until it sits flush.
    • Re-enable the Built-in Battery 1. Power on the laptop and press F1 to enter the BIOS setup. 2. Navigate to Configuration > Power using the arrow keys. 3. Highlight Enable Built-in Battery and press Enter.
    • Testing the Display 1. Power on the system and verify the new display is functioning correctly. 2. If issues are observed, double-check the cable connections before fully securing the laptop.
Andrew Elijah Dezelle
crwdns2935283:010/03/22crwdne2935283:0
88 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 5-3, Eggleston Fall 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 5-3, Eggleston Fall 2022crwdne2935289:0
CMCSC-EGGLESTON-F22S5G3
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 1,450
