This is a very simple replacement that acts as a prerequisite for hard drive replacement. It involves just the use of a Phillips #0 screwdriver and small plastic opening tool.
Flip the laptop upside down so that the battery is facing away from you.
Locate the three 3 mm Phillips #0 screws on the back panel.
Remove each screw using a small Phillips #0 screwdriver.
Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
