This guide is for removing the ThinkPad X100e's LCD display and replacing it with a new one.
crwdns2935267:0crwdne2935267:0Spudger$2.99
Use a Spudger tool to remove the screw covers on each side of the screen.
Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
Pry open the bezel carefully with the spudger tool.
Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
Remove the connector located at the very top of the screen beside the webcam.
Fold the panel over until a strip of black tape is visible.
Peel the tape down until you get to the base.
Peel the piece of transparent tape back.
Remove the connector carefully with the spudger tool.
Remove the black tape fully.
Now your device is ready for a new panel.
What can be used as a replacement screen, as it's listed not for sale?
