Lenovo ThinkPad X100e Fan Replacement
  1. Lenovo ThinkPad X100e Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer over and remove the battery.
    • Please view the Battery Replacement Guide if more detailed instructions are needed.
  2. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screws on the back of the laptop. Unscrew all 7 screws using a magnetic screwdriver fit with a PH0 bit.
    • All 7 screws should be bounded to the panel.
  3. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws with a magnetic screwdriver fit with a PH0 bit.
    • There should be 2 screws total.
  4. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  5. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the magnetic screwdriver fit with a PH0 bit, unscrew the two screws shown in the picture.
  6. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two wired ribbons by pulling up the little black tabs, then pull the wires out.
  7. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the little black wire by simply pulling it out.
  8. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, go beneath the frame to pry the frame off the device.
    • The best place to start from is the bottom, near the trackpad.
    • Place the frame aside once this step is completed.
  9. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the magnetic screwdriver, unscrew all 8 screws shown.
    • Be sure to place all your screws on the magnetic mat.
  10. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the three wired ribbons on the top left side of the panel.
  11. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the wired plug, then close the device and flip it over.
  12. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Simply pull the two plugs up and out to disconnect the wires.
  13. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device back over to untape the two black wires located at the bottom left corner of the device.
  14. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Simply disconnect the blue connector at the center of the device.
  15. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, slowly push the panel out of the plastic body.
    • Place the plastic body aside once the panel is free.
  16. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the same magnetic screwdriver, unscrew the two screws as shown in the picture.
  17. Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X100e Fan Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the plug right below the Fan. A pair of pliers might be useful during this step.
    • If you need to clean your cooling fan, simply spray compressed air onto the fan to clean in and rid it of debris. Repeat the previous steps in reverse order to put your laptop back together.
    • If you need to replace your cooling fan, simply place your new fan in, and follow the steps in reverse order to put your device back together.
Then you are good to go.
Claire Hall
crwdns2935283:002/08/18crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S2-G2, Thomas Spring 2018 crwdns2935289:0University of North Texas, Team S2-G2, Thomas Spring 2018crwdne2935289:0
UNT-THOMAS-S18S2G2
crwdns2942667:0crwdne2942667:0 1,384
