Lenovo ThinkPad X1 Yoga Motherboard Replacement
  1. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
    Bei der Variante mit integriertem UMTS-Modul die SIM-Karten-Schublade herausnehmen, sonst klemmt die beim Abheben der Gehäuse-Unterseite!
    Fxuser - crwdns2934203:0crwdne2934203:0
    Pry from the side of the hinge first.
    Dante Horatio - crwdns2934203:0crwdne2934203:0
  2. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Speakers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Cooling Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 4.5mm Phillips #1 screws from the corners of the heat sink.
    CAUTION you will need to re-apply thermal paste to the CPU and GPU if you remove the fan.
    This step is not necessary if you are only trying to access the keyboard and trackpad, or remove the monitor. If so, the steps of removing the Wifi and SSD are also not necessary. Skip to Step 16 Motherboard.
  8. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel back the black plastic covering around the fan.
    • You may hear or feel the adhesive pulling away here.
    • Using an iFixit opening tool, flip up the small black cover of the fan plug.
  9. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, pull the plastic strip out.
  10. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fan from the computer.
    How does the user remove the fan?
    Sandy Branham - crwdns2934203:0crwdne2934203:0
    ****** BEFORE re-assembly
    1- clean material off of cpu (careful!)
    -- use a tool with a dull edge to scrape away the thermal conductive paste on the processor and the heat sink (the processor is the chip under the heat sink, the heat sink is the x shaped assembly that is attached to the fan
    2. apply a fresh coat of NEW thermal paste to the processor, then re-mount the heat sink
    -- google "applying thermal paste to CPU" for hints and tips about the right amount of paste to use and the correct ways to apply it.
    eric jmail - crwdns2934203:0crwdne2934203:0
    Really bad advice! For anyone who's reading, you DO NOT need to remove the fan (or heatsink)! The motherboard can be removed as a whole. This is a totally unnecessary step.
    Mahmoud - crwdns2934203:0crwdne2934203:0
  11. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Wireless chip: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel back the black plastic covering.
    • Remove the single Phillips #1 screw securing the wireless chip in place.
  12. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iFixit opening tool to gently pop the gold caps off their connections.
    • Move these wires out of the way.
  13. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the chip out.
  14. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Hard Drive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
  15. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the hard drive from the computer by pulling away from the computer.
  16. Lenovo ThinkPad X1 Yoga Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement, Motherboard: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the iFixit opening tool, flip up the eight small covers from the cable connectors.
    • Gently pull the cables out of the slots.
  17. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove sixteen 4.5mm screws.
  18. Lenovo ThinkPad X1 Yoga Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the motherboard away from the computer.
Emily Perkins
crwdns2935283:002/20/20crwdne2935283:0
357 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G16, Eggleston Spring 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G16, Eggleston Spring 2020crwdne2935289:0
CMCSC-EGGLESTON-S20S3G16
Do you have closeup pictures of the 16Gb vs the 8Gb model? I am planning on upgrading the RAM and need to know the RAM IC chipnames and possible configuration resistors.
Help is much appreciated.
anonUser7893409 - crwdns2934203:0crwdne2934203:0
According to this link the memory is soldered onto the motherboard and it's 2666MHz DDR4 (they specify it's actually 3200 MHz but running at 2666 MHz due to system limitations).
This site has a picture of the motherboard, but I'm not sure if it shows the actual memory chips. It does show the SSD.
Hope this helps, all the best of luck!
maktecfam -
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 102
crwdns2942667:0crwdne2942667:0 5,838
