Use a Phillips #1 screwdriver to remove the five 5.0 mm screws from the base panel.
Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
Lift the base panel up and off of the chassis.
Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
Lift the battery up and out.
Use a spudger to pry the coin cell battery until it releases from the chassis.
Use a spudger to "walk" out the coin cell's plug from its motherboard port, gently levering from each side until it releases.
Lift the coin cell battery out.
Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
Use the spudger to lift the flap covering the speaker wire.
Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
Lift the speakers up and out.
Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
Lift the copper plate up and out.
Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
Use a Phillips #000 screwdriver to loosen the four 5 mm captive screws.
Place the pointed tip of a spudger behind the small plastic tab on either side, and "walk" the fan's connector out of its port, alternating between tabs, until the plug disconnects.
Lift the fan up and out.
Use a Phillips #1 screwdriver to remove the two 5.0 mm screws that secure the headphone jack.
Use tweezers to lift the headphone jack to the right to free it from the chassis.
Use a Phillips #1 screwdriver to remove the four 3.0 mm screws that secure the USB port.
Use tweezers to pull the USB port to the right to free it from the chassis.
Use a Phillips #1 screwdriver to remove the nine 3.2 mm screws from the motherboard.
Use a plastic spudger to lift the flaps covering the pins. Disconnect the pins from the motherboard.
Use a plastic spudger to disconnect the two wires connected to the CPU.
Use a plastic spudger to disconnect the pin on the bottom left of the motherboard.
Lift up the motherboard on the left hand side.
Pull the motherboard to the left to free from the body chassis.
Use a Phillips #1 screwdriver to remove the two 3.2mm screws securing the stylus.
Use a Phillips #1 screwdriver to remove the one 4.0mm screws securing the stylus.
Lift the stylus out of the chassis.
Use a spudger to get under the connector ribbon and peel it off of the plastic covering.
Use a spudger to get under the clear plastic and peel it off of the keyboard and trackpad.
Use a spudger to lift the flap covering the pins of the ribbon.
Pull the ribbon down to disconnect from the trackpad.
Use a Phillips #00 screwdriver to remove the fifty-eight 2.0 mm screws securing the keyboard.
Wedge a spudger between the keyboard and the chassis to lift the keyboard out of the shell.
Use a Phillips #1 screwdriver to remove the four 2.0 mm screws securing the trackpad.
Lift up the body shell for the keyboard to remove the trackpad.
