Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement
  1. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Back cover removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Back cover removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Battery disconnect: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Battery disconnect: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Battery disconnect: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to peel back the plastic shield covering the battery connector.
  5. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up on and disconnect the battery cable.
  6. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement, Thermal Fan Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the thermal fan assembly connector with your fingers and gently pull upwards to disconnect it from the motherboard.
  7. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 3mm Phillips #0 heat sink screws following the numerical order engraved into the heat sink.
  8. Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad X1 Carbon 7th Gen Thermal Fan Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the heat sink mounting brackets and lift up to remove the thermal fan assembly.
    • Heat sink may still be hot if laptop was recently powered off.
    • When removing the heatsink, it's always good to apply a new layer of thermal paste, as it helps the heat sink pull heat away from the CPU.
Jaxon Haws
crwdns2935283:001/23/20crwdne2935283:0
613 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G2, White Winter 2020 crwdns2935289:0Cal Poly, Team S19-G2, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S19G2
crwdns2935297:021crwdne2935297:0
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 4,147
