In this guide, you will learn how to replace the motherboard in a Lenovo ThinkPad X1 Carbon 6th Gen. Be sure to power off your device and disconnect it from any power source before beginning.
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Jimmy to lift the cover directly up off of the locating pins.
Remove the back cover.
Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
crwdns2935267:0crwdne2935267:0Nylon Tipped Tweezers$4.99
Use nylon tipped tweezers, or your fingers, to gently pull the fan's power cable towards the SSD, disconnecting it from the pins.
Use a plastic opening pick to lift the fan mount.
Use your fingers to gently pull the fan diagonally away from where it is connected.
Turn the fan over to expose the interior.
If necessary, clean out the fan or wipe away and replace the thermal paste.
Remove each of the 7 main ribbon cables that connect the motherboard to the rest of the laptop.
Detach the last ribbon cable in the same way as before.
For the red and orange cables, use a spudger to lift the black plastic bar.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place a spudger under the cables to disconnect them from the WLAN card.
Use a Phillips #00 screwdriver to remove the two 3mm screws that secure the IO bracket.
Remove the two 3mm antenna bracket screws using a Phillips #00 screwdriver.
Lift from the location of the screw towards you. Then pull towards the screw side to remove the bracket.
Lift the white and black wires from their press on connections. Make sure to grab the connector head, not the wire itself
Remove and unscrew the two 5mm screws with a Phillips #0 screwdriver.
Using an iFixit SIM card screw head tip, apply pressure to the hole to disconnect the SD card slot from the device.
Use a Phillips #00 screwdriver to remove each of the four remaining 3mm screws securing the motherboard to the device.
Lift from the top of the motherboard towards you.
Pull away from the IO port side to remove the motherboard.
crwdns2935229:05crwdne2935229:0
Step 3 should be removing the battery. There are 4 screws to do this.
is it true these boards have a problem and stop functioning? I bought it at Costco 2-3 years ago. My computer won't power on and my local tec shop thinks this is the problem. I like it bc is light and small and since I paid $1100 for it I think I should get a little more life out of it, right? I just bought a new battery too. thanks.
(X1 Carbon 6th Gen - (Type 20KH, 20KG) Laptop (ThinkPad) - Type 20KG; 8th Generation Intel® Core™ i7-8550U Processor(Core i7-8550U) Machine Type Model: 20KG0022US.)
