Lenovo ThinkPad W540 Display Replacement
  1. Lenovo ThinkPad W540 Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad W540 Display Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open your laptop so that the screen is at around a 180 degree angle.
    • Using a plastic opening tool, pry open the outer frame of the display.
    • Generally, it is best practice to start from the corner first, and then guide the opening tool around the the frame.
  2. Lenovo ThinkPad W540 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad W540 Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew the four 3 mm screws holding the display, one for each corner.
    • Once unscrewed, flip the display over the other side of the laptop (keyboard end).
  3. Lenovo ThinkPad W540 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad W540 Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger, safety lift the adhesive tape from the connector.
    • Do not disregard the tape from the connector entirely as you will be reusing it later.
    • This adhesive tape will be strong, remove the tape carefully to prevent damage to the display connector.
  4. Lenovo ThinkPad W540 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Safely disconnect the display from the connector.
    • Although you can use your hands to disconnect the connector, it is recommended that you use a spudger instead.
Kevin Dang
crwdns2935283:010/30/23crwdne2935283:0
360 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-2, Konn Fall 2023 crwdns2935289:0UMass Dartmouth, Team 3-2, Konn Fall 2023crwdne2935289:0
UMASSD-KONN-F23S3G2
crwdns2942667:0crwdne2942667:0 550
