Lenovo ThinkPad T560 Battery Replacement
  1. Lenovo ThinkPad T560 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
    The big problem here is where to find a new internal battery. I wish I had some suggestions to make, and would welcome possibilities. Searching on the Lenovo parts site has not proved fruitful--if you've had some success, I'd be glad to hear of it! These are pretty good computers, and battery failure is the main thing sending them to the landfill.
    carter - crwdns2934203:0crwdne2934203:0
  2. Lenovo ThinkPad T560 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T560 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
Jackson Reynolds
crwdns2935283:002/27/22crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-3, Hunter Spring 2022 crwdns2935289:0Clemson, Team 1-3, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S1G3
Is there any way to disable the battery whitelist or otherwise get the device to work with 'unauthorized' external batteries as OEM external batteries are no longer produced by Lenovo or sold by any vendor including ifixit itself? I've had some that worked for close to a year now up until yesterday, when the laptop suddenly decided they are no longer official.
David L. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 4,321
