If you need to replace the Solid State Drive (SSD) on your Lenovo ThinkPad T495s, this is the guide for you! SSDs use flash-based memory, which is much faster than a traditional hard drive. Installing an SSD in your laptop is one of the best ways to speed up your laptop.
Flip the laptop over to reveal the back panel of the laptop.
Loosen the five 4.0 mm captive screws with a Phillips #1 screwdriver.
Use a Phillips #1 screwdriver to unscrew one 2.2 mm screw at the bottom of the SSD.
Use your hands to pull the SSD toward yourself, removing the SSD.
thank you sis but dont tell me that doesn’t have a ram ??
