Lenovo ThinkPad T495 Battery Replacement
  1. Lenovo ThinkPad T495 Battery Replacement, Baseplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four screws securing the battery.
    • On both sides of the plug, use your fingernails to "walk" out the battery cable connector until it releases.
  4. Lenovo ThinkPad T495 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by lifting it up and out with your fingers
    • The battery should lift out with no resistance. If you feel any resistance, double check that the screws are removed, and that the connector is released from the motherboard.
Christian Taylor
crwdns2935283:003/28/22crwdne2935283:0
655 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-6, Petersen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-6, Petersen Spring 2022crwdne2935289:0
UMASSD-PETERSEN-S22S1G6
Can you tell me where the screen led power would be
levi martin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 242
crwdns2942667:0crwdne2942667:0 7,552
