Lenovo ThinkPad T490s - Thermal Paste Replacement
  1. Lenovo ThinkPad T490s - Thermal Paste Replacement, Opening the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T490s - Thermal Paste Replacement, Opening the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T490s - Thermal Paste Replacement, Opening the back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all screws holding the back panel in place.
    • Use a prying tool to release all the clips and remove the panel.
  2. Lenovo ThinkPad T490s - Thermal Paste Replacement, Changing the thermal paste: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T490s - Thermal Paste Replacement, Changing the thermal paste: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T490s - Thermal Paste Replacement, Changing the thermal paste: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnecting the battery is highly recommended.
    • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
    • Clean the old thermal paste from both the cooler and the CPU.
    • Use isopropyl alcohol and cotton swabs or paper towel, but be careful not to press too hard on the CPU.
    • It's also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Use only enough thermal paste to cover a portion of the pad. Use a spreader if you have one.
    • The thermal paste will apply evenly after you tighten the heatsink.
    • Place the heatsink back into the unit carefully and tighten the screws in an "X" pattern to ensure even pressure. Don't forget to plug in the fan cable.
    Thermal paste should not be applied to the second die/processor as it is the chipset, not a GPU/CPU.
    When opening up the laptop, only one is covered in paste, this is the CPU and the other is left un-pasted as it would be adversely affected by heat transference from the CPU. The chipset/un-pasted die does not generate a large amount of heat.
    Hernando Gonzalez - crwdns2934203:0crwdne2934203:0
    Yes, that is true. However it is still better to cover the second die as well, for better performance. This will not affect the heat transferance as this laptop does now have trouble with overheating.
    Simeon Brankov -
  3. Lenovo ThinkPad T490s - Thermal Paste Replacement, Other upgrades: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have the back cover opened, it is a good opportunity to upgrade the SSD. To do so, follow the SSD Replacement Guide.
Simeon Brankov
crwdns2935283:011/08/20crwdne2935283:0
7,399 crwdns2915208:0crwdne2915208:0
crwdns2935297:054crwdne2935297:0
Are you sure thermal paste should be applied to the smaller PCH die?
Bryan C - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 146
crwdns2942667:0crwdne2942667:0 6,231
