This guide demonstrate how to replace the USB board in your Lenovo ThinkPad T470s.
The USB board works as a communication tool between your external USB devices, such as a flash drive or mouse, and your computer.
The USB Board of your Lenovo Thinkpad T470s can be damaged by misuse and rough handling of external USB devices.
An indication of a failing USB board would be if your external USB devices are no longer being read by the laptop correctly, if at all.
Power off and unplug your device before beginning.
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Use a Phillips #0 screwdriver to remove the two 3.3 mm screws.
Use your fingernail to flip up the gate, then pull the connector directly out of the port.
Lift the USB board up and out of the chassis.
