This guide will walk you through the steps for replacing the motherboard in your Lenovo ThinkPad T470s.
The motherboard works as a nervous system for the computer; it allows components, such as the Wi-Fi card and RAM, to "communicate," running the operating system and your computer.
Motherboards can be damaged by rough handling, drops, water damage, or power surges.
Some possible indications of a failing motherboard are: your external USB devices are no longer being read by the laptop correctly, if at all; the laptop is operating much slower than usual; the computer boots with the blue screen of death, and/or any burning smell coming from the laptop while operating.
Power off and unplug your device before beginning.
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
Peel back connecting supporting tape on each of the batteries.
Slide the upper battery out of the device, away from the laptop.
Slide the lower battery out of the device, away from the laptop.
My laptop says Battery 1 is at 0% and does not hold a charge and Battery 2 is at 88% and I have 4h 22min of estimates time remaining. Which battery do I need to replace? Upper or lower?
You would think Lenovo would make this information readily available. Im in their manual right now. Not seeing anything. Extremely annoying. Will just use a trial and error method removing one and see if thats the defective one.
Looks like battery 1 is the larger battery.
If I remove battery 1 or 2 will there be any problem running my laptop?
Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
Remove the heatsink and fan from the laptop.
Wipe off the old thermal paste with either 99% isopropyl alcohol or kimwipes.
Follow this guide to reapply new thermal paste.
Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
Grip the Wi-Fi card on both sides, then pull it directly out of its port.
Use a Phillips #0 screwdriver to remove the two 3.3 mm screws.
Use your fingernail to flip up the gate, then pull the connector directly out of the port.
Lift the USB board up and out of the chassis.
Locate the SSD slot between the large battery and fan.
Remove the screw securing the SSD using a Phillips #000 screwdriver.
Slide the SSD out of the motherboard.
Flip up the locking gate, then pull the cable directly out of its port.
Use a Phillips #0 screwdriver to remove the single 3.3 mm screw on the top right corner of the motherboard.
Remove the single 3.3 mm screw with a Phillips #0 screwdriver.
Use a Phillips #0 screwdriver to remove the single 2.9 mm screw.
Disconnect the speaker connection covering the screw.
Use a Phillips #0 screwdriver to remove the single 5 mm screw securing the motherboard.
Remove the 3.3 mm screw using a Phillips #0 screwdriver.
Use a Phillips #0 screwdriver to remove the 3.3 mm screw.
Gently grip the motherboard and slide it to the right to remove the USB ports from the chassis.
Lift the motherboard up and out of the chassis.
This seems to be missing several steps: track pad and power cable…
This is missing that you need to remove the keyboard as well. There are ribbon cables attached to the keyboard on the bottom on the motherboard
There are some conections that need to be disconected before baing able to take out the board anda you did it but didnt mentioned
