This guide requires some caution when removing the cables connected to the wireless adapter. Use a spudger and avoid using tweezers with metallic points as it could damage the cable. The remainder of the guide is simple and requires unscrewing a screw.
Flip the laptop so that the back is facing up.
Slide the battery latches to the unlocked position.
Slide the battery pack out of the battery slot.
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
Use the spudger to remove the two cables that are connected to the wireless adapter.
Use a Phillips #0 screwdriver to remove one 3 mm screw holding down the wireless adapter. Once it is done, the wireless adapter will move to an upward angle.
