The back cover is the protective layer for your computer that covers many components that will likely be replaced. The process is very simple and you will only need to remove two screws with a Phillips #1 screw driver.
Flip the laptop so that the back is facing up.
Slide the battery latches to the unlocked position.
Slide the battery pack out of the battery slot.
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
