This guide will show you the steps to safely remove the damaged integrated camera from your laptop. The integrated camera is located above the screen of your laptop, which is usually used to take pictures, create videos, and chat with others.
Place an opening tool under the screen cover, and pop it off.
Take off the 6 screws using the Philips head #1.
Remove the connector located at the bottom of the back of the screen.
Unplug the connector. It is located on the top of the screen attached to the camera assembly.
crwdns2935267:0crwdne2935267:0Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use the 3.0 flathead to lift up the silver camera strip.
