This guide will give you the instructions needed to replace the laptop's cooling fan. The fan is needed to keep the laptop from overheating.
Remove the 8 screws holding down the back panel using the Phillips screw driver #000.
Remove the 9 wafer-head screws, size M2x4mm, using the Phillips screwdriver #000.
Remove the fan's cable using the plastic opening tool.
Gently, remove the black and white wires surrounding the fan.
