This tutorial will show how to replace a built-in battery on a Lenovo ThinkPad HK11e with the 14 inch screen.
Make sure the Lenovo laptop is shut off.
Turn over laptop and lay it on its face exposing the back-plate screws.
Find the six screws that hold together the back plate.
Carefully unscrew the six 3.3 mm screws that fasten the back plate using the T5 Torx screwdriver.
Use a plastic opening tool or a spudger to carefully remove the back plate.
Battery is located in the bottom right portion of the laptop.
Find the three screws that mount the battery.
Carefully unscrew the three 3.5 mm screws that fasten the battery down using the T5 Torx screwdriver.
Notice a connector that joins the battery to the laptop.
Slowly disconnect the connector by pulling back on the six-wire harness.
Remove the battery from its assigned location.
Reverse steps to mount new battery correctly.
