Lenovo ThinkPad Edge E420s Keyboard Replacement
  1. Lenovo ThinkPad Edge E420s Keyboard Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
  6. Lenovo ThinkPad Edge E420s Keyboard Replacement, Top Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement, Top Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
    • Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
  7. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M3 x 2mm screw from the hole left by the hard drive using a Phillips #00 screwdriver.
  8. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip over the device.
    • Open the device normally.
  9. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the plastic opening tool between the upper and lower halves of the lower case.
    • Lift the end of the opening tool slowly until the case separates.
    • Hearing a small popping or cracking noise during this step is normal
  10. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the upper half of the case up slowly.
    • Be sure not to yank any of the wires connected to the case as this could damage them.
  11. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and disconnect the 4 ribbon wires from the top case.
    • Locate and disconnect the two additional connecting wires.
    • Some wires may be connected by a clamp. In order to remove the clamp, press upwards on the lever attached to the connector
    • Be careful to not yank on the wires when disconnecting them as they are easily damaged.
  12. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the unattached case away from the device and place it to the side.
    • When reassembling ensure that all parts of the case are properly aligned.
  13. Lenovo ThinkPad Edge E420s Keyboard Replacement, Keyboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the top case and turn it over so you can see the back of the keyboard.
  14. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to push out the metal spacers holding the keyboard in place.
    • After the metal spacers have been disconnected, the keyboard may simply fall out. If not, apply a small amount of pressure to pop it off.
  15. Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad Edge E420s Keyboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard away from the rest of the case.
Keyadri Summerlin
crwdns2935283:010/02/18crwdne2935283:0
1.003 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S2-G1, Karnes Fall 2018 crwdns2935289:0Linn Benton Community College, Team S2-G1, Karnes Fall 2018crwdne2935289:0
LBCC-KARNES-F18S2G1
crwdns2942667:0crwdne2942667:0 635
