Turn the laptop over so that the bottom is facing upwards.
Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
Carefully remove the back panel.
Carefully remove the black and white coaxial cables that are connected to the chip using an opening tool.
Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
Carefully grab the chip and pull outward to remove it from the laptop.
