This guide will walk you through how to replace the keyboard on your Lenovo ThinkPad E570 laptop. If your keys are malfunctioning even if your drivers are up to date, you may need to replace the keyboard.
Be sure to power down, unplug, and remove the battery before beginning this guide.
Turn the laptop over so that the bottom is facing upwards.
Remove the three 5 mm screws using a Phillips #0 screwdriver.
Flip the laptop over and open the lid.
Gently press against the keyboard and slide it up.
Pull up keyboard from the casing and flip it towards you to access its cables.
Unlatch two connector cables from the keyboards and pull the skinny black tab up to disconnect the keyboard.
