This guide shows you how to gain access to the buzzer ringer component of the speaker for its replacement.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
Using a counterclockwise motion with the Phillips #000 screwdriver, unscrew the three M1.4 × 2.5 screws that hold the white plastic speaker housing in place.
Pry off the speaker housing utilizing a metal spudger.
Insert a plastic probe through the tab and pry to remove the speaker from its socket.
Using a soldering iron, desolder the contacts that connect the speaker wires to the speaker chip.
