This guide illustrates the procedure to remove the front-facing camera of your device.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
Using tweezers, peel off the anti-static sticker from the camera connection port.
Lift the camera out of its socket in the motherboard. Then, using tweezers to grasp the camera connector, carefully pull the connector horizontally out of the port.
Using tweezers to grasp the camera connector, lift the camera out of its socket.
