Lenovo Tab 2 A8 Battery Replacement
  1. Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
    • With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
  4. Lenovo Tab 2 A8 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Tab 2 A8 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Working your way around the edge of the battery, pry out the battery using a plastic opening tool
    • Be aware that the battery is held in by double-sided tape on the underside
crwdns2935229:05crwdne2935229:0
Carli Ollerman
crwdns2935283:010/08/15crwdne2935283:0
263 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-4, Plummer Fall 2015 crwdns2935289:0Eastern Washington University, Team 2-4, Plummer Fall 2015crwdne2935289:0
EWU-PLUMMER-F15S2G4
crwdns2935297:013crwdne2935297:0
Thanks... but where do we find a replacement battery?
sebtrudel - crwdns2934203:0crwdne2934203:0
I fixit might have a replacement battery
storm builder - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 12,358
