In order to remove and replace the power button on your tablet, a soldering iron will be needed.
Use a plastic opening tool to pry open the back cover of the tablet.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently use the precision tweezers to separate the power button strip from the interior frame of the tablet.
Remove the power button from the motherboard.
Use the soldering iron to heat up the connections. Gently pull away from the motherboard after connections are detached.
Thank you for making this helpfull instrutions.
Where i can get the Buttons?
