Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement
  1. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement, USB 2.0 Power Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement, USB 2.0 Power Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the unit over so the bottom is facing you.
    • Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
  2. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
    • If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
  3. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the device tray by inserting a paper clip into the eject hole.
  4. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two silver 3mm Phillips #0 screws from the mini USB circuit board.
  5. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
  6. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the silver cover to expose the internal components.
    • If the cover seems stuck gently pull up on one edge. The cover should remove completely after one side is free.
  7. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two ribbon cables using any pair of ESD(electrostatic discharge) safe tweezers.
    • The ribbons wires are fragile but still require a firm force to remove.
  8. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFixit Opening Tool to flip up the grey locking flap on the ZIF (zero insertion force) connector to allow removal of the ribbon cable.
    • Remove the large ribbon wire using any pair of ESD safe tweezers.
  9. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 3mm Phillips #0 screw to loosen the large circuit board.
  10. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the large circuit board and slide it through the opening with the ribbon cable attached to it.
    • The large circuit board should end up on the other side of the device next to the Mini USB circuit board.
  11. Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Slim DVD Burner DB65 USB 2.0 Power Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power assembly by peeling it away from the unit.
    • The two circuit boards, which make up the power assembly, are connected together with a white ribbon cable.
    • Take your time when removing the power assembly, as it requires a firm amount of force to peel away and remove.
Matthew Green
crwdns2935283:007/05/18crwdne2935283:0
358 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G1, Harley Summer 2018 crwdns2935289:0IUPUI, Team S2-G1, Harley Summer 2018crwdne2935289:0
IUPUI-HARLEY-SU18S2G1
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,445
