Lenovo N23 Keyboard Replacement
  1. Lenovo N23 Keyboard Replacement, Removing the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing upwards.
    • Use a Phillips #1 screwdriver to remove the eight 6.6 mm screws in the bottom.
  2. Lenovo N23 Keyboard Replacement, Opening up the keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Chromebook over and open the lid.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Be careful of the tabs on the inside of the keyboard and Chromebook, these could break too.
    • Run the plastic tool along the seam, popping up the keyboard until you can freely lift up the keyboard.
    • It is normal for the tabs to make loud popping sounds when released. The corner tabs are harder to remove and will make a louder click when released.
  3. Lenovo N23 Keyboard Replacement, Releasing the keyboard from the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the keyboard is released, grab the top two corners closest to the lid and slowly lift the keyboard up.
    • Do not lift the keyboard too quickly, or you might break the two cables that connect the keyboard to the motherboard.
    • The motherboard is now exposed. DO NOT use any tools with metal or you may short circuit and fry the motherboard.
    • Disconnect the cables by lifting up on the retaining tabs on the blank ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N23 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keyboard up and off of the back retainers completely removing the keyboard from the Chromebook.
Robin Mores
crwdns2935283:005/06/19crwdne2935283:0
166 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,600
