Lenovo N22 Chromebook Individual Key Replacement
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N22 Chromebook Individual Key Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
crwdns2935229:013crwdne2935229:0
Jackson Tucker
crwdns2935283:004/26/17crwdne2935283:0
869 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S21-G1, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S21-G1, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S21G1
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - crwdns2934203:0crwdne2934203:0
Where can I order individual keys?
Mallory Montreuil - crwdns2934203:0crwdne2934203:0
He tried to turn it on but it did not work
Clayton Sensing - crwdns2934203:0crwdne2934203:0
I took it off and now it broken he he
BRENNEN FIRKUS - crwdns2934203:0crwdne2934203:0
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - crwdns2934203:0crwdne2934203:0
My kid spilled sweet tea on his keyboard and the G and F were sticking. I was able to take off the keys by pushing the key from the left and then right edges enough for the plastic tab to clear the hole and come through. I applied more force than I was comfortable with for the key to come off but the two plastic pieces came off with it and separated. I had to reassemble them, correctly, and then put the key in at the lowest position and then push slide up to lock the plastic pieces in place along with the key. I honestly feel like I was going to break it when it came out the first time.
Charlie Dillard - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 15,296
