Lenovo N22 Chromebook Battery Replacement
  1. Lenovo N22 Chromebook Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N22 Chromebook Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up on the tabs that were held down by the screws to remove the battery.
crwdns2935229:010crwdne2935229:0
Kevin Yerina
crwdns2935283:004/26/17crwdne2935283:0
453 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S21-G1, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S21-G1, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S21G1
thanks I needed to take the bottom off so I can take a certain screw
xian panadero - crwdns2934203:0crwdne2934203:0
That's way too much just to take the battery out. it was helpful having these steps. Thank you
Becky Breneman - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 17,170
