Lenovo N21 Chromebook Battery Replacement
  1. Lenovo N21 Chromebook Battery Replacement, Keyboard and Trackpad Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement, Keyboard and Trackpad Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
    Where is write Protect Screw ???
    Please
    Lenovo N21 Chrome Book
    MAC IT - crwdns2934203:0crwdne2934203:0
  2. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
    My replacements did not come with the trackpad zif. I had to remove from the old part and move to the new part.
    Michael Selburg - crwdns2934203:0crwdne2934203:0
  7. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard and trackpad panel away from the device.
    Has anyone gone through the experience of replacing JUST the keyboard? It looks like they are available as a separate component, e.g. https://www.ebay.com/itm/New-for-Lenovo-... but I haven’t found a tutorial on removing the keyboard from its bezel. Thanks!
    mbates - crwdns2934203:0crwdne2934203:0
  8. Lenovo N21 Chromebook Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the white charging cable connectors by pulling straight down on the connector.
  9. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo N21 Chromebook Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery.
  10. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel up on the silver cable enough to remove the adhesive to the battery.
    • When moving the adhesive cable, be careful not to disconnect or damage the cable and motherboard.
  11. Lenovo N21 Chromebook Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by pulling back and up.
Jacob Taylor
crwdns2935283:004/26/17crwdne2935283:0
260 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S21-G2, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S21-G2, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S21G2
Great step by step instructions!
M Mikusa - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,188
