This guide replaces the USB port for the Lenovo Legion Y530-15ICH, overtime with use it make break/get water damaged. This is especially important if the user needs to connect a smartphone.
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7mm screws
Two 6mm screws
Four 4mm screws
Carefully pry the back cover off the computer using an opening pick.
Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
Gently disconnect the single ribbon cable with your fingers.
Remove the USB port from the device.
