Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
Lift the bottom panel off of the chassis.
Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
Pull the Wi-Fi card directly out of its port.
