This guide explains how to replace the hard drive in your Lenovo Legion. You may be replacing a fried hard drive or you may be upgrading memory. A hard drive can also be removed in order to put a solid state drive in place.
Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
The bottom piece will make popping noises as it is pulled from the laptop.
The hard drive is a white square located on the right side of your device.
Use a Phillips #00 screwdriver to remove four 4.0 mm screws holding the hard drive in place.
Slide the hard drive from the device towards your right.
crwdns2935229:08crwdne2935229:0
Hi,
does anyone know if replacing the 1TB hard disk with a 1TB SSD is possible? (I’m thinking in terms of cloning the whole disk: can I go for a 1TB SSD or do I need a bigger one? Do hidden partitions for restoring the system / this kind of stuff get copied correctly? Most tutorials online just copy the Windows partition: wouldn’t want to find out I can’t reset the system if needed.)
