This guide will walk you through the steps on how to replace your Levono Legion y520 fan. In cases when your fan maybe overheating or not working you will need this guide. NOTE: There are a lot of wires. Be sure to keep track of where each one goes.
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
Lift the bottom panel off of the chassis.
Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
Unscrew all the screws then unplug the wires connected to the fan.
crwdns2935229:010crwdne2935229:0
Superb guide. thank you random citizen for creating this guide
Do I need to remove the fan if I want to clean it or add oil?
Is there a way to open the fan to clean the dust from the blade ?
