Lenovo Ideatab S6000 Motherboard Replacement
  1. Lenovo Ideatab S6000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
    I little bit of heat goes a long way when taking off the speaker screens.
    iHelpU.Tech - crwdns2934203:0crwdne2934203:0
  2. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from both of the spots that were covered.
  3. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the plastic that is covering the battery cable.
  5. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  6. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
    MERCI POUR LE TUTORIEL, et courage pour vulgariser la technique!
    KISANTU - crwdns2934203:0crwdne2934203:0
  7. Lenovo Ideatab S6000 Motherboard Replacement, Speakers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideatab S6000 Motherboard Replacement, Speakers: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideatab S6000 Motherboard Replacement, Speakers: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The speakers are connected to the tablet by glue and require a lot of prying to remove.
    • Make sure to get all the way under the speakers when prying.
  8. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step is not necessary if you aren't replacing the speakers.
    • To the remove the wires heat the solder connecting the wires to the board, and gently pull on the wires.
    • Remember the placement of the red and black wires.
    • Connect new speakers by soldering the wires onto the board.
  9. Lenovo Ideatab S6000 Motherboard Replacement, Vibration Motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry up the vibration motor.
  10. Lenovo Ideatab S6000 Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.16mm screws highlighted in red
  11. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Force the ribbon cables out by pulling up the cables through the use of the plastic opening tool.
  12. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the black tab up to unlock the cables by using the plastic opening tool.
  13. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the piece of tape by pulling it up through the use of your hand.
  14. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape by pulling it up through the use of the plastic opening tool.
  15. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlike the other small connectors this one does not flip up. You need to pull the connector cable to release this
    • Lift the tab by pulling it up with your hand.
    On this connector, the white portion of the tab lifts up rather than the black portion.
    jpkennard - crwdns2934203:0crwdne2934203:0
    Don't forget the Camera connector on the opposite side! :) Almost missed him.
    Mikel Farley - crwdns2934203:0crwdne2934203:0
  16. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the cables connected to the tab by using the spudger tool.
  17. Lenovo Ideatab S6000 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the tablet's Motherboard by lifting it up with your hands.
crwdns2935229:08crwdne2935229:0
Josiah Speed
crwdns2935283:009/22/14crwdne2935283:0
965 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-4, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-4, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G4
Just followed this on my father's tablet, worked like a charm!
One step missing, there's a connector for the camera between steps 16 and 17 that needs pried up before taking the board off.
Other than that THANK YOU!!! :)
Any schematics or board view for this board out there?
DANIEL HOCH - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,352
