Guide the user in replacing the battery in order to fix power related problems of the Lenovo Ideatab S6000.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
Remove the screws from both of the spots that were covered.
Go all around the casing, prying the screen away from the backing with the spudger.
It will make a popping sound each time one of the lock tabs is disconnected.
Pull off the plastic that is covering the battery cable.
Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
Remove the battery by grabbing the tab shown and pulling up.
The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
MERCI POUR LE TUTORIEL, et courage pour vulgariser la technique!
crwdns2935229:016crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Does this guide apply to all variants of this model? The S6000L frame doesn't seem to pop away from the screen assembly the same way. Is there adhesive in any of the models?
Can you recommend a professional who can help replace my Lenovo S600 battery.
The original Lenovo battery comes with the metal frame. In my case, the screw holes of the metal frame did not fit the screw holes of the base. Thus, I just pulled the new battery off its metal frame and just replaced the battery.
Great information. Thanks, you're a peach!
It was helpful.
I little bit of heat goes a long way when taking off the speaker screens.
iHelpU.Tech - crwdns2934203:0crwdne2934203:0
