Lenovo Ideatab A1107 Front Camera Replacement
  1. Lenovo Ideatab A1107 Front Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Front Camera Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the tape covering the battery's wiring.
  5. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
    • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
    • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
  6. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge a plastic opening tool in between the battery and the internal components of the device.
    • Use the plastic opener tool to remove the battery from its casing.
  7. Lenovo Ideatab A1107 Front Camera Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using you hands, lift off the digitizer.
  8. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three screws that are 2.0 mm in length and have a 5.25 mm head width with a Phillips #00 screwdriver.
  9. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to remove the plastic piece securing the zero insertion force (ZIF) cable connector.
    • Use tweezers to grasp the ribbon cable, then pull the cable to disconnect it from the device.
  10. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the black electrical tape strip on the side of the device.
    • Gently remove the tape from the device using the tweezers.
  11. Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the electric tape, gently lift up the green control panel.
    • Taking the tweezers, remove the ribbon cable from the control panel.
    • Once the ribbon cable is removed from the panel, the display should separate with ease.
  12. Lenovo Ideatab A1107 Front Camera Replacement, Front Camera: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideatab A1107 Front Camera Replacement, Front Camera: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, pull and remove the front camera component.
Katherine Enders
crwdns2935283:001/18/17crwdne2935283:0
445 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-2, Crane Winter 2017 crwdns2935289:0Eastern Washington University, Team 2-2, Crane Winter 2017crwdne2935289:0
EWU-CRANE-W17S2G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 196
