Lenovo Ideapad Flex 4-1570 RAM Replacement
  1. Lenovo Ideapad Flex 4-1570 RAM Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the RAM cover with a spudger.
    • Although a metal spudger is shown in the photo, an ESD-safe nylon spudger is recommended.
  5. Lenovo Ideapad Flex 4-1570 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not attempt to pull the RAM out without first pulling up the metal release brackets.
    • Gently remove the RAM by pulling up the metal release brackets, pushing the RAM forward out of its port, and lifting it up and out.
Leslie Kaid Kravat
crwdns2935283:002/12/22crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 2-13, Eggleston Spring 2022 crwdns2935289:0The Citadel Military College of South Carolina, Team 2-13, Eggleston Spring 2022crwdne2935289:0
CMCSC-EGGLESTON-S22S2G13
Simple and easy to follow guide, thank you! The Flex 4 I was working on had two additional 10mm screws in the top corners, this may be a later revision.
Chris Horry - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 338
