Lenovo Ideapad 320-15ABR Screen Replacement
  1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
    • Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
    • This will require some force, but take care not to break the hinge cover.
    • Remove the black cover.
    The hinge cover does not come off as described. The small plastic tabs that hold it in place are interlocked. You remove the hinge cover by sliding it to the right about 1/8th inch otherwise you will likely break some of the tabs. This requires further disassembly first as the top frame does not provide the space needed to slide the hinge cover over. You must first remove the display assembly from the base.
    hall999999 - crwdns2934203:0crwdne2934203:0
  2. Lenovo Ideapad 320-15ABR Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 320-15ABR Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 320-15ABR Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the four 3mm screws securing the screen, and put them on the magnetic mat so you will not misplace them.
    • Gently lift the screen out and place it facing down on the keyboard.
  3. Lenovo Ideapad 320-15ABR Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 320-15ABR Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 320-15ABR Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip the hinge securing the connector up with the opening tool.
    • Slowly work the plug out of the connector.
    • Do not pull by the the cable, as the cable is fragile.
    • Insert the plug from the replacement screen in to the connector. Make sure the connection is secure before flipping the hinge back down.
rheinheimer.n
crwdns2935283:010/29/18crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team S1-G5, Hingst Fall 2018 crwdns2935289:0Purdue University Northwest, Team S1-G5, Hingst Fall 2018crwdne2935289:0
PNW-HINGST-F18S1G5
crwdns2935297:019crwdne2935297:0
How to replace hinge for this model
Deepak Singh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 4,723
