Lenovo Ideapad 120s-14IAP Touchpad Replacement
  1. Lenovo Ideapad 120s-14IAP Touchpad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14IAP Touchpad Replacement, USB Daughterboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement, USB Daughterboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
  5. Lenovo Ideapad 120s-14IAP Touchpad Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
    • Pull on the plastic film to remove the display connection cable.
  6. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, disconnect the connections for the right speaker.
    • Using tweezers, disconnect the connections for the battery.
    • Using tweezers, disconnect the connections for the CMOS battery.
  7. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
  8. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven 2.5 mm Phillips #0 screws from the motherboard.
    • Slide the motherboard out of the laptop chassis.
  9. Lenovo Ideapad 120s-14IAP Touchpad Replacement, Touchpad: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement, Touchpad: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove five 2.5 mm Phillips #0 screws from around the battery.
    • Lift the battery out of the laptop.
  10. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 2.0 mm Phillips #0 screws from the speaker assemblies.
    • The speakers can now be lifted up.
  11. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 2.5 mm Phillips #0 screws from the battery bracket.
    • Lift the battery bracket out of the laptop.
  12. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 5.0 mm Phillips #0 screws from the screen hinges.
    • You can now lift the bottom cover and separate each half of the laptop.
  13. Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo Ideapad 120s-14IAP Touchpad Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The touchpad retention screws are hidden beneath a strip of adhesive. Gently peel the adhesive away to access them.
    • Remove three 2.0 mm Phillips #0 screws from the touchpad retention bracket.
    • The touchpad now slides up and can be removed.
Nathaniel Lott
crwdns2935283:009/17/19crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G4, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G4, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G4
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 989
