Step by step guide to replacing the Wi-Fi card in your Lenovo 110-11IBR.
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Remove the two pieces of tape that are holding the battery down.
Remove the five 4 mm Phillips screws securing the battery.
Lift the battery up and out of the device.
Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
Unscrew the one 4mm screw keeping the card in place.
Gently pull the Wi-Fi card out of place.
