This guide will allow any owner of a Lenovo Ideapad 110S-11IBR to undergo the process necessary to remove and replace the touchpad of the device to allow for removal. To do so, simply follow the given steps, starting with the removal of the back panel, then the battery, followed by a simply metal plate, and then the touchpad itself. To reassemble, simply follow the steps in reverse order.
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Remove the two pieces of tape that are holding the battery down.
Remove the five 4 mm Phillips screws securing the battery.
Lift the battery up and out of the device.
Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
Use a plastic opening tool to remove the touch pad.
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
