This guide will teach you to replace the battery of the Lenovo Ideapad 110S-11IBR, if faulty or to service another part.
Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Remove the two pieces of tape that are holding the battery down.
Remove the five 4 mm Phillips screws securing the battery.
Lift the battery up and out of the device.
crwdns2935229:08crwdne2935229:0
Great instructions but where can you by a replacement battery? I can’t find one anywhere.
