Lenovo IdeaPad Z570 Screen Replacement
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Z570 Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Daniel Lopes
crwdns2935283:003/08/19crwdne2935283:0
619 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G6, Botvin Spring 2019crwdne2935289:0
UMASSD-BOTVIN-S19S1G6
crwdns2942667:0crwdne2942667:0 1,222
