Before preceding with this guide make sure to remove the battery. Also make sure to be in an open space with ample desktop space when proceeding.
Place the laptop face down with the battery facing away from you
Push the battery forward lightly to remove it while holding the left switch.
Place the laptop face down with the battery slot facing away from you.
Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
Remove the back panel from the device.
Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
Gently remove the disc drive from the left hand side of the laptop.
