The top assembly contains the keyboard and trackpad. Removing it allows access to the logic board, battery, and RAM.
Position the laptop so that the bottom enclosure is facing upward.
Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
Use an opening tool to carefully pry up the rubber pads.
Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
Flip the laptop over and swing open the display.
Lift the edge of the keyboard closest to the trackpad up.
Carefully disconnect keyboard ribbon cable from the laptop.
Remove the keyboard.
Remove the two screws securing the midframe.
Grab the front edge of the top assembly and lift it up carefully.
Gently slide the three ribbon cables out of their slots.
Remove the top assembly completely by pulling it off of the device.
You need to remove the keyboard too otherwise you will miss the 2 screws underneath!
this is a terrible guide, you unlatch the ribbons in the prior step with screws.
I’m pretty sure all you need to do is remove 4 screws on the back (2 under the foot pads on the upper side and 2 in the middle, all beneath the keyboard), then loosen the keyboard from the top slide forward and up, not the whole cover, then the dimm slot is right there
I am looking into buying one of these but looking at your pictures I can't find the SSD. Is it user upgradeable?
under the rubber pads can be, or are? the bottom pads are much more secured.
zZz - crwdns2934203:0crwdne2934203:0
2 of them. The 2 near the screen hinges. They release the keyboard.
jsoper - crwdns2934203:0crwdne2934203:0
Mine had t5 Torx screws on the perimeter and center, with #0 phillips underneath the foot pads.
dan lench - crwdns2934203:0crwdne2934203:0
Mine also had the T5 Torx screws.
Willem -
