Lenovo IdeaPad Yoga 11S RAM Replacement
  1. Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
    under the rubber pads can be, or are? the bottom pads are much more secured.
    zZz - crwdns2934203:0crwdne2934203:0
    2 of them. The 2 near the screen hinges. They release the keyboard.
    jsoper - crwdns2934203:0crwdne2934203:0
    Mine had t5 Torx screws on the perimeter and center, with #0 phillips underneath the foot pads.
    dan lench - crwdns2934203:0crwdne2934203:0
    Mine also had the T5 Torx screws.
    Willem -
  2. Lenovo IdeaPad Yoga 11S RAM Replacement, Remove Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Yoga 11S RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Yoga 11S RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
    You need to remove the keyboard too otherwise you will miss the 2 screws underneath!
    jonesadam08 - crwdns2934203:0crwdne2934203:0
    this is a terrible guide, you unlatch the ribbons in the prior step with screws.
    I’m pretty sure all you need to do is remove 4 screws on the back (2 under the foot pads on the upper side and 2 in the middle, all beneath the keyboard), then loosen the keyboard from the top slide forward and up, not the whole cover, then the dimm slot is right there
    Jeff Ferguson - crwdns2934203:0crwdne2934203:0
  5. Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the RAM module.
    • Locate the tabs on both sides of the RAM module
    • Spread both tabs outward at the same time in order to release the RAM module.
  6. Lenovo IdeaPad Yoga 11S RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the RAM module and carefully pull it out from its position.
Landon Epps
crwdns2935283:003/26/15crwdne2935283:0
982 crwdns2915208:0crwdne2915208:0
Baylor, Team 7-11, Williams Spring 2015 crwdns2935289:0Baylor, Team 7-11, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S7G11
Excelente… easy and simply.
Iver Antelo - crwdns2934203:0crwdne2934203:0
At Step 3. Replace the memory now that it is exposed. You don't have to do steps 4-5, I don't think you have to remove the 10 small screws either.
Just the Philips under the foot tabs and carefully remove the keyboard, pull the tabs back that secure the memory and replace with new memory.
Kyle Brock - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,372
