This guide provides details on how to replace the display on a Lenovo IdeaPad Y700-15ACZ laptop. The Lenovo IdeaPad Y700-15ACZ uses a FHD 15.6" 1920x1080 display.
Before you begin, you will need a PH0 bit or screwdriver and the new display. This is a very fragile component, so exercise caution when disassembling the device. You may need this guide if your device is failing to display images on the screen, but audio and the device is still powered on.
Remove the border around the screen using a plastic opening tool.
Use a Phillips #0 screwdriver to remove the four screws that secure the display (one screw at each corner).
Before you remove or rotate the display, remove the cable connected to the display from the constraints.
Rotate the display face down.
From the sticker carefully peel down and remove the connection from the display.
Attach the ribbon to the new display.
Repeat steps backward to put the computer back together. After you have completed the reassembly, make sure to test the new display by powering on the device.
